vayne1 Posted April 6, 2021 Share Posted April 6, 2021 I usually run my HD500 to my amp via FX Return out to the Return input on my amp head. Has worked fine for a while and now my HD500 FX Return stopped working. I get no signal at all. I can get the unit to work when I run from the Phones jack but that is a temporary fix. I've seen mention of checking the FX Loop setting. Should send and return both say 100% as well as mix? I just want to find this and fix it before I waste time finding a tech and find out it's not a jack issue but when I did an update a setting got changed. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 6, 2021 Share Posted April 6, 2021 36 minutes ago, vayne1 said: I usually run my HD500 to my amp via FX Return out to the Return input on my amp head.... Surely you mean the FX Send out to the Return of your amp? Check your cabling. Quote Link to comment Share on other sites More sharing options...
