Darrell999 Posted April 9, 2021 Share Posted April 9, 2021 So I'm using Helix Edit, and I have snapshot 1 for my clean tone. Save. So then I raise the gain on the amp for snapshot 2. Save. But then when I switch to snapshot 1, it still shows the raised gain on the amp! I must be missing something obvious, but what am I doing wrong? Quote Link to comment Share on other sites More sharing options...
PierM Posted April 9, 2021 Share Posted April 9, 2021 You need to press the gain encoder, and then dial the value. This will place a keyframe there, to be stored in the snapshot. 1 Quote Link to comment Share on other sites More sharing options...
Darrell999 Posted April 9, 2021 Author Share Posted April 9, 2021 Thanks, PierM! I wanted to just use the Edit software for this. For anyone else who has this problem, here's what I just found out by....yup, READING THE MANUAL: ;) "To Store a Block’s Bypass State Per Snapshot - Click on the Bypass button above any block within the Signal Flow and set your desired bypass state for the block (or you can toggle the block’s Bypass button within the Edit tab). Any amp or effects block’s Bypass state will, by default, be remembered and recalled per Snapshot." 1 2 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 9, 2021 Share Posted April 9, 2021 WOW! They still produce manuals? .... jk ;-) 1 Quote Link to comment Share on other sites More sharing options...
