Firehawk died suddenly, won't power on...
DTHPWN
This Sunday, I was playing and my FH suddenly died. No sound, no lights, nothing. I checked the power adapter and the green light was flashing. I switched the unit's power switch off and the power adapter light went solid green. Turned the power on again, nothing - green LED on the power adapter starts flashing again. Tried several different outlets, same result. When I switch the FH on, no lights on the FH at all, power adapter LED flashes. Turn the power switch off, power adapter LED goes solid green again.
  • 3 weeks later...
Maybe the SdCARD inside the FH
Set the power OFF
Remove it and put it again can help !
to access this card , remove the screws at the back (inside de liitle plastic supports) not the screws at the middle
remove the panel to slide it to left or right and pull up
remove the screws at the backside (the one on the left) is not the same as the other( keep this apart)
Remove the jack screws
Remo the electronic plate where the all the inputs are carefully turn it a little bit (Take care about the cable)
you will see  a SD card at the left try to remove it and replace it
If you are lucky it can work again !
Go to facebook and join the Firehawk Group https://www.facebook.com/groups/1786436751639919/  you will see a topic about the SD CARD !
