Having trouble editing snapshots hx effects
Samdbl
So I don’t have the a computer handy, so I must edit this snapshot manually. I’m trying to get a pedal in the chain to turn on for just one snapshot. However, I go into edit mode, and that particular pedal is not listed. Just a blank space. But it is clearly in the signal flow/chain. Why is it not appearing in the edit mode. So how do I get it in there, so I can edit it?
I'm not sure what you're referring to as "Edit Mode" here... There isn't really such a mode (there's Pedal Edit Mode, but that doesn't sound like what you're describing here). I'm thinking you're probably talking about Stomp Mode. Not all blocks have to be assigned to stomp switch, so if a block isn't assigned to a stomp switch, you can just go to Signal Flow View navigate to that block, and select what footswitch you want to assign it to by turning Knob 3 (Knob 3 corresponds to the "Switch" parameter in the scribble strip above FS2).
By the way, I should add, the faster way to add a block is to do it directly from Stomp Mode. You just hit the footswitch for the empty scribble strip, and you'll see the prompt that tells you to turn the big knob to select a block. You select the block there, and the bypass assignment will be made to that switch automatically. If you need to move the block in the signal chain, you can then go into Signal Flow view, navigate to the block, and then move it using Knob 1.
https://youtu.be/6y0JbXC7RnU
Well looking at this vid starting at about 3:05 is what I’m getting at. I want a pitch shifter block turned on for on snapshot and turned off for the other. This guy goes to snapshot, hits the mode/edit button which brings up all the pedals, turns one of them of and then hits save, which saves that for whatever snapshot you happen to be on. Since when I do this, the pitch pedal doesn’t appear with the other pedals (even though it’s there as a block in signal flow), I’m wondering how I’d do this.
 I pretty much explained it, didn’t I? What I described above is how you go about assigning the block to a footswitch.
