AB Switch Pedal for two Variax guitars going into Helix?
Hi folks,
I use two Variax guitars on stage - one is a back up, should a string break during a gig. I'd like both to be controllable via my Helix - so for this, I need to use Variax Digital Cables.
Does anyone know if there's an AB Switcher Pedal, which I could plug both my Variax guitars into, then one output goes into the "Variax" input on the Helix? Being able to switch between the two would mean I can avoid kneeling on stage to plug/unplug them.
There are some RJ45 switch/splitter selector boxes available online. However, none of them can accommodate the secure Neutrik casings of the Variax Digital Cables. I could purchase cables with Neutrik casings one end, and the standard ethernet connections the other. However, the standard ethernet connection wouldn't be very secure, and would cause problems if it jiggles around.
Cheers!
Edited by circu5
Clarity
