iamthetony2 Posted April 30, 2021 Share Posted April 30, 2021 For some reason, since I upgraded to 3.11 for HX Edit and my Helix LT, they no longer recognize .hlx format patches. Instead it reads .hls. Perhaps I missed something? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 30, 2021 Share Posted April 30, 2021 3 hours ago, iamthetony2 said: Perhaps I missed something? Yep, the .hls file indicates that it is a Setlist not a preset file. You don’t say how you are trying to load the files, but I would suggest that you try again. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 1, 2021 Share Posted May 1, 2021 This^^^. Is it possible you are using the Import command off the yellow task bar towards the very top of the librarian section of HX Edit titled "SETLISTS" ? To import presets you want to use the Import command from the section below it in white labeled "PRESETS". As always make sure your HX Edit version is the one that corresponds to your firmware version. 1 Quote Link to comment Share on other sites More sharing options...
iamthetony2 Posted May 3, 2021 Author Share Posted May 3, 2021 [UPDATE] I did realize I was trying to load it as a set list after about 1 minute of realizing that mistake on my part. LOL! HOWEVER, When I tried loading it the right way (Import Preset) it still would not work with the preset my younger brother sent me that he made on Helix Native. I did get a response back from service and was given a link to update the HX Edit software as well. For some reason this software is version 3.01 even though my Helix LT is updated to 3.11. I honestly didn't see a download for 3.01. I thought that was the update I downloaded when I searched for the latest version of HX Edit. IF it works out , then great. Hopefully it'll help someone else who may have the same thing happen to them. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 3, 2021 Share Posted May 3, 2021 The latest version of HX Edit is 3.10. That's what you should be using with firmware version 3.11. Quote Link to comment Share on other sites More sharing options...
iamthetony2 Posted May 3, 2021 Author Share Posted May 3, 2021 Thanks. After support sent me 3.01 HX Edit immediately upgraded to 3.10. I thought I had downloaded it before I updated my Helix to 3.11 actually. Quote Link to comment Share on other sites More sharing options...
