oliverbutler17 Posted May 24, 2021 Share Posted May 24, 2021 Hey there, I am wanting to set up a preset with split outputs: 1. 1/4" - no IRs to go into a power amp & cab for stage sound 2. XLR - 2 IRs to go DI to FOH I have figured out how to use two IRs in parallel but am wondering if it is possible to do 2 in parallel with the split outputs? Thanks Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 24, 2021 Share Posted May 24, 2021 yes it's possible: You take a block and add it to your chain. Then drag it down in HX Edit, it creates a parallel path. So then you change the output of both outputs: one is 1/4, the other is xlr. And you can add any stuff to each path, however you want. What I do is have 2 identical signals go to the power amp/cab and FOH, even if it's already colored with an IR. Lots of people do it that way and have great success. For example, I played a gig and they had no xlr DI's, only 1/4 inch ones, so I didn't have to bring any adapters; all my outputs output the same exact sound: xlr, 1/4, headphone. Hope it helps. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 24, 2021 Share Posted May 24, 2021 Instead of using the 1/4" out to the amp, place a send block before the split to your parallel IRs and use the send (LINE level if 4cm) for the amp. 2 Quote Link to comment Share on other sites More sharing options...
