btmlinedan Posted August 2, 2021 Share Posted August 2, 2021 Is it possible to add more boxes in to add more effects? For example I want to do a volume pedal (exp1 for signal chain 1 aka guitar and exp2 for signal chain 2 aka vocals) but can't seem to add any boxes. Does anyone know how I can do this? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 2, 2021 Share Posted August 2, 2021 8 total assigned anyway you'd like but only 8 and that assumes you don't run out of DSP first 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted August 2, 2021 Share Posted August 2, 2021 To get more than 10(8 FX 2 AMP) blocks, you will need to move to Helix LT or full Helix. HD is an 10 block dual chain modeler. 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 2, 2021 Share Posted August 2, 2021 but there are tricks for some effects. For example: If all you want is a volume change - assign the EXP pedal to the amp's volume knob instead of taking up a block with a volume pedal. 1 Quote Link to comment Share on other sites More sharing options...
btmlinedan Posted August 2, 2021 Author Share Posted August 2, 2021 3 hours ago, pianoguyy said: but there are tricks for some effects. For example: If all you want is a volume change - assign the EXP pedal to the amp's volume knob instead of taking up a block with a volume pedal. Thank you! I'm actually not using any amp's as this is all acoustic + Mic stuff currently. I wonder if there's a way around that... Quote Link to comment Share on other sites More sharing options...
