POD GO Bank Buttons Question
jwoertz
On the POD GO, when you are in Snapshot Mode and hit the bank up or bank down button, does it show you the patches in that current bank or does it go up a bank as default? I need to be able to hit the bank up/down buttons and first see the current bank, not upper or lower banks.
For snapshot mode, you can set the up/down to either switch snapshots, switch preset or bank.
-When up/down is set to preset, it goes to the next preset (5B -> 5C -> 5D) and as you switch preset, the default preset of the new patch is activated.
-When set to bank, it shows you the 4 presets of your current bank, and hitting up/down a 2nd time shows you the next/previous bank, you select one, then it activates the preset and the default snapshot of the preset.
-Next snapshot is well next snapshot.
So for Bank, if you're in 4A, and hit up, you'll see 4A-4D, if you hit up a 2nd time, you'll see 5A-5D.   If you're in 4A and you hit down, you'll see 4A-4D, hit down a 2nd time, 3A-3D.  So looks like it works like you want.  :)
Should be on their way in the forthcoming update, as these were top of Line 6s Pod Go to do list.
Its been 'extrapolated' on The Gear Page that based on Helix/ Stomp timescales, we should see it in late August. I appreciate that's not official and Line 6 never give much of a clue as even they don't know until a day or so before, but Pod Go really is due a proper firmware upgrade about now.  Not counting bug fixes it's only had one since launch and that only imported some models from Helix 3.0 but gave no functionality upgrades. So I do feel Line 6 needs to get this done.
