lukeskip Posted September 20, 2021 Share Posted September 20, 2021 I have the following singal chain that I'm trying to set up properly for practice playback so I can perform and run tracks simultaneously: Electric guitar > Helix LT > Focusrite audio interface (linked to PC) > headphones or studio monitor. My audio interface works fine when I run tracks through it from my pc but when I switch on the LT I get zero signal when I touch the guitar except for occasional earsplitting singal overload sounds that seem to come when I literally touched nothing. I have no idea what to do at this point. I've checked the i/o quarter inch cables and they work just fine. I'm convinced something is wrong with the LT. Actually I know its the LT because when I hook it up to direct amp it still doesn't create sound. Current firmware is 3.11.0. And yes I have performed a factory reset. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 20, 2021 Share Posted September 20, 2021 Since you KNOW it's the LT, open a support ticket. There's nothing we can do for you here. If it's under warranty, they'll take care of you. If it's used AND out of warranty, they'll tell you where to send/take it for repair. My only comment/suggestion is, with the LT disconnected from everything but the power and guitar, are you getting signal from the headphone jack? 1 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 21, 2021 Share Posted September 21, 2021 On 9/19/2021 at 10:11 PM, lukeskip said: Actually I know its the LT because when I hook it up to direct amp it still doesn't create sound. Current firmware is 3.11.0. And yes I have performed a factory reset. Just curious.... have you tried a FULL factory preset, without loading your presets back in? Corrupted presets can be a nightmare... which is why I am asking. Some reset options keep existing presets which will not solve this problem. 1 Quote Link to comment Share on other sites More sharing options...
