roddo Posted October 23, 2021 Share Posted October 23, 2021 I recently purchased a Pod Go in September. Played through it for a about an hour just to see if it functioned correctly and to demo some of the amp sounds. I had to go on a business trip for a few weeks and now back home I started to go through the presets with my guitar and bass. When i selected the bass amp models there a number of bass amps missing. So I went ahead and installed the Pod Go Editor, followed the update instructions and the Pod Go updated to 1.30 hoping the missing bass amp models would appear. Nope. I tried the factory rest with the same results, missing certain bass amp presets. These are what is missing from the bass amps: Ampeg SVT-4 Cali 400 Ch2 Del Sol 300 Busy One Ch 1 Busy One Ch2 Busy One Jump Studio Tube Pre Is there anyway to install the the missing Presets or does my Pod Go need to be returned? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 23, 2021 Share Posted October 23, 2021 Are you looking on the hardware or on the editor? Make sure you have the latest version of POD Go Edit installed. Quote Link to comment Share on other sites More sharing options...
roddo Posted October 24, 2021 Author Share Posted October 24, 2021 The Editor on my PC and my Pod Go have the exact same Presets. The Pod Go Editor and the Pod GO both have the 1.30 update. Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 24, 2021 Share Posted October 24, 2021 3 minutes ago, roddo said: The Editor on my PC and my Pod Go have the exact same Presets. The Pod Go Editor and the Pod GO both have the 1.30 update. Oh... I missed that you're talking presets... When I read your post earlier, I assumed you were talking about the models themselves. I just double-checked, and there are no factory presets using those models, at least that are named after the model like the other models. Quote Link to comment Share on other sites More sharing options...
roddo Posted October 24, 2021 Author Share Posted October 24, 2021 In the Pod Go Edit-Pilot's Guide v1.30, it lists the amps (presets?) in the section listing the "Amp/Preamp Models". So I would assume my Pod Go should include those missing amp/preamp models. Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 24, 2021 Share Posted October 24, 2021 Your Pod Go firmware probably does include those amp models. But it seems there are no factory presets that explicitly name/use them. You can create your own presets that use them by selecting them from the amp models list that appears when you add/change an amp model during preset editing. Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 24, 2021 Share Posted October 24, 2021 1 hour ago, roddo said: In the Pod Go Edit-Pilot's Guide v1.30, it lists the amps (presets?) in the section listing the "Amp/Preamp Models". So I would assume my Pod Go should include those missing amp/preamp models. You’re confusing the presets with the models. Presets are a particular signal chain using certain blocks. The models are the actual amp, cab and effects that you can use to build those presets. The models are all there, it’s just there aren’t any factory presets using them. There are quite a few models, most probably, that don’t show up in any factory presets. Quote Link to comment Share on other sites More sharing options...
roddo Posted October 24, 2021 Author Share Posted October 24, 2021 Thank you for the replies and info. I'll experiment with the Pod Go as soon as I can. I love the form factor and what the unit is capable of. It does more than i actually need, but options are always a plus. Quote Link to comment Share on other sites More sharing options...
