HX Stomp Snapshot Button Is Not White??
soundog
When in Snapshot Mode on a Stomp, I thought all three buttons LEDs (and the button text on the display) were supposed to be white.
On my Stomp, the 2nd button is red on all of my presets! Is there someway to turn the button back to white (other than a hard reset)?
The only way I can see to set (or UN-set) the color of a button in a snapshot is in CommandCenter.
And, although the setting is in there, it doesn't seem to work, which IIRC, is a known bug.
Even if it DID work, I can't see why that one button is red in ALL of your presets, unless you've been using a template preset?
And since it doesn't work, how did the button get red in the first place?
VERY strange, indeed!
IDK, do a backup and reset. That's where I'd start.
Thanks. Its a mystery. I double checked .... its not all presets, its all of the recent ones which I'll bet I based on a single preset which carried the red gene. I have a lot of older presets, further down the list, that are all white. How the carrier preset turned red we may never know, although I do a lot of wacky customization/experimentation at times. Something got buggered.
I'm gonna do a backup and reset. I'll come back and add to this note when I'm done...
OK, I just did a backup, full reset, and restore. Nothing changed! The 2nd button was still red on all my newest presets. I assumed something was buggered in the preset files.
So, the quick fix was to edit the hlx files using a text editor. I just had to change @ledcolor from 2 to 0 in snapshot1 (which is dimmed white, and it auto changes to bright white when the button is selected).
Steps: export preset, edit and save hlx file (as above), import preset (into the same location). It didn't take long at all, an I only had to do 23 presets.
Ouch! Thankfully I have no such problem. If you ever figure out how it happened, do come back and tell us!
  1. Snapshot mode
  2. press Upper Knob
  3. select the offending Snapshot using Knob 2
  4. press Action button
  5. press Rename Snapshot = Knob 1
  6. press Page> button
  7. set Switch LED to Auto = Knob 3
  8. Save preset
Or use HX Edit: ctrl/right-click the snapshot name and change the color from the context menu.
(Yeah, I'm using color LEDs with snapshots a lot… :)
  • Thanks 1
  • Upvote 2
