problem with variax line 6 700 trem and workbench hd
I've got a problem with variax line 6 700 trem and workbench hd, i downloaded the variax workbench but isn't working the older monkey version finding the variax workbench but not my guitar and the new version of monkey is only finding the workbench hd , workbench hd is saying i need to install variax workbench, i really don't know what to do , could somebody help me please,
my interface is working and the monkey has all updated but still nothing, i work with macOX10.11.6
thank you
Tremolo for a Variax 700 Electric won't fit in a Standard bridge.
Workbench HD is compatible with Mac OS 10.11.6 El Capitan.
- Disconnect any USB hub connected to the computer.
- Make certain the interface is connected directly between guitar and computer.
- Insert a fully charged battery into Variax battery compartment.
- Insert a tip/ring/sleeve 1/4" headphone adapter into the 1/4" jack.
- Once the relay clicks and both LED's are green, then you are ready to go.
  • 4 weeks later...
On 12/9/2021 at 5:17 PM, rexkatze said:
thank you for your help but it still doesn't work
got still the same problem
Workbench HD  The connected Variax is not compatible with Workbench HD. You must use a James Tyler Variax version 2.00 or higher.
Good afternoon. Just today I was trying to adjust the 1st string volume on my 700, for whatever reason it is lower than the other 5. Variax 700 into my PODHD500X and into the computer, Windows 10,  and got the message that there is no supporting workbench any more for the 700.  It appears as if I do not have any option to  adjust it at this point and "it is what it is". Please confirm or recommend a solution if there is one. thank you.
