Helix stomp FX
dazzer20
I am using my helix stomp for effects only and using it my  Tube amps fx loop , Can anyone explain how i  route the FX on the Helix  stomp, example say i want some of my  FX going in the front and some not how do i set this up from inside the helix stomp .
You can find a diagram of how to connect your HX Stomp and your amp using the 4 cable method on page 9 of the HX Stomp 3.0 Owner’s Manual - Rev D - English. You should also be able to find an example set-up in the TEMPLATES factory setlist that ships with your hardware. That should put you on the right track.
Hope this helps/makes sense.
