Trying to adjust tone in a snapshot and it is changing other snapshots
lespool79
I have successfully made quite a few presets and snapshots.  This is going very well.
But then sometimes like today I get stuck in this situation:
snapshot 1 is clean.  it has a nice sparkling chorus and is a clean tone.
snapshot 2 is dirty.  the factory preset I found has two amps and I have the drive set up higher to crunch.
snapshot 3 is LESS DIRTY with a delay on it.
When I go to adjust the gain on snapshot 3 it cuts the gain on snapshot 2 as well.  I can't figure that out?  I am saving the preset after I make the adjustment in snapshot 3 but it is overriding the gain on snapshot 2.  What am I missing here?  Snapshot 1's gain is not messed with, only snapshot 2 and 3 seem to be mirroring each other.
On 3/9/2022 at 9:58 AM, silverhead said:
Are you sure the Drive parameter is assigned to the Snapshots controller?
I must not be aware.  I'm in HX edit and I click on the snapshot, make changes and then hit save preset.  it seems to work but not for this.
You need to select a parameter, right-click on it and assign it to snapshots.  Then the parameter value will be in [brackets].  Then you can select a snapshot and inside of it make parameter changes.  These changes will be applied to the snapshot only.
If you don't do this, then each time you make a change, you overwrite the entire preset.
