Thatguy7070 Posted March 24, 2022 Share Posted March 24, 2022 Just got my Helix and I’m trying to toggle between wah and volume using the built in expression pedal. Currently the wah is set to exp1, the volume exp2, and I can’t figure out how to switch between the two. thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 24, 2022 Share Posted March 24, 2022 Push the expression pedal forward to activate the hidden toe switch under the toe portion of the pedal. Quote Link to comment Share on other sites More sharing options...
kduck Posted March 25, 2022 Share Posted March 25, 2022 On 3/23/2022 at 10:35 PM, phil_m said: Push the expression pedal forward to activate the hidden toe switch under the toe portion of the pedal. What @phil_m said + you have to push the toe down kinda hard when they're new--they break in after a while. Quote Link to comment Share on other sites More sharing options...
Thatguy7070 Posted March 25, 2022 Author Share Posted March 25, 2022 Still nada. I’m pushing and banging on this thing and still not switching Quote Link to comment Share on other sites More sharing options...
Thatguy7070 Posted March 25, 2022 Author Share Posted March 25, 2022 Are you guys talking about the mission pedal? I’m just trying to go from exp2 to exp1 using the heavy metal built in pedal Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 25, 2022 Share Posted March 25, 2022 On 3/23/2022 at 11:14 PM, Thatguy7070 said: Just got my Helix and I’m trying to toggle between wah and volume using the built in expression pedal. Currently the wah is set to exp1, the volume exp2, and I can’t figure out how to switch between the two. thanks Assuming that you have tried restarting the device and don't have any external expression pedals connected. As you just received your Helix you may want to double check your rear panel and make sure you don't have anything plugged into the 'EXP 2' jack just to be thorough. As @kduck advised, you'll want to test by pushing toe-down, quite firmly, on a hard surface to activate the expression toe-switch. No stomping required but stand up and put some weight on it. Just to be clear, couldn't tell for sure from the pictures, is the issue that it is not switching from volume to wah, or is it that it is not switching from 'EXP 1' to 'EXP 2' in the scribble strip? When functioning properly the scribble strip will highlight the selected EXP and dim the deselected EXP. Does this happen on all/any preset(s)? If the scribble strip is changing properly, you may just have an issue with your preset's assignments. If the scribble strip above the expression pedal never changes then you might have a hardware problem. However, before I opened a ticket with Line6, since you just got your Helix, I would probably try a backup, factory reset (hold down FS9 & FS10 upon restart for the Helix), and then restore backup. What version of the firmware are you on? Quote Link to comment Share on other sites More sharing options...
Thatguy7070 Posted March 25, 2022 Author Share Posted March 25, 2022 I’m on the newest firmware. I’m attempting to get it to switch from EXP2 to EXP1, and no matter how much weight I put on this thing it just won’t switch. It does this with all presets Quote Link to comment Share on other sites More sharing options...
Thatguy7070 Posted March 25, 2022 Author Share Posted March 25, 2022 Factory reset fixed it! Weird Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 25, 2022 Share Posted March 25, 2022 On 3/25/2022 at 4:13 AM, Thatguy7070 said: Factory reset fixed it! Weird Great! I'll take weird but fixed any day of the week. 1 Quote Link to comment Share on other sites More sharing options...
