Gdjazz Posted April 13, 2022 Share Posted April 13, 2022 I loaded an IR but it causes my HX Stomp to be silent. The IR works fine in the Boss GT-1000CORE. The wav file is 2 seconds, Stereo, 44.1kHz, 24bit. Any reason why this can't work in the HX Stomp? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 13, 2022 Share Posted April 13, 2022 Too long. You need 200ms. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 13, 2022 Share Posted April 13, 2022 Here's a link to better explanation: Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 13, 2022 Share Posted April 13, 2022 On 4/13/2022 at 4:04 AM, Gdjazz said: The wav file is 2 seconds, Stereo, 44.1kHz, 24bit. Any reason why this can't work in the HX Stomp? Hi From the HX Stomp 3.0 Owner's Manual - Rev D - English, page 32. IR Formats For all Helix/HX family devices, as well as Helix Native plugin, the following IR file types are supported. Helix Impulse Response (.hir) - This is the proprietary Line 6 IR file format. All IRs purchased through the Line 6 Marketplace are of this file type—see “Marketplace” on page 5. WAV (.wav) - Most IR producers and vendors typically offer IRs within the .wav format. It is possible to import a mono or stereo .wav file IR, regardless of its bit depth, length, or sample rate frequency. Upon import, IR .wav files are automatically converted to 48kHz sample rate, 32-bit, mono, and 2,048 sample length for Helix. You can use the HX Edit app’s Preferences to set the preferred behavior for importing Stereo https://line6.com/data/6/0a020a418962611d636e7c51b/application/pdf/HX Stomp 3.0 Owner's Manual - Rev D - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
