Nos402 Posted April 23, 2022 Share Posted April 23, 2022 So I took a chance on a third party Variax battery that was cheaper and also has a slightly higher capacity. I knew it was possibly a gamble, but It SEEMS to work fine. One quirk is that while normally charged batteries get the slow blinking light (like my other original Variax battery), this one gets the fast blinking "faulty battery" light. Is it possible that it's just because it's not an official Line 6 battery? I've only used it once so far, but when inserted it shows 4 dots and seems to have a normal duration I think (though I've never tried going more than one gig on a single charge yet). Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 25, 2022 Share Posted April 25, 2022 Third party batteries have been nothing but problems. It's cheaper for a reason,... it's cheaper. You run the risk of damaging the guitar circuit or the charger, don't use third party batteries. Quote Link to comment Share on other sites More sharing options...
Markveber Posted January 3, 2024 Share Posted January 3, 2024 The fast blinking light might indeed be because it's not an official Line 6 battery, and the Variax might have some sort of built-in check for that. But here's the thing, if it's showing 4 dots and holding up during your gigs, it sounds like it's performing just as well as the original. Plus, you mentioned it has a slightly higher capacity, which could even be a bonus. Sometimes, these third-party options can be hidden gems. Just keep an eye on it, especially during extended use, to make sure it continues to perform as expected. If it does, you might have found yourself a cost-effective alternative without compromising on quality. You can always check out options like ACE Battery storage solutions for more alternatives. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 5, 2024 Share Posted January 5, 2024 One LED blinking fast is when the battery is flat and needs to be charged up. Li-Ion batteries don't come from the retailer full charged, you have to charge them up when you get them. Quote Link to comment Share on other sites More sharing options...
