Aeolus_000 Posted April 25, 2022 Share Posted April 25, 2022 Hey guys. I have tried to use Helix Native with a bass guitar and having some pretty weird results. I am going through a Radial DI and into a Scarlett 18i20. The input level seems mostly fine, it could be a tiny bit higher. Of the 3 things here in the signal chain, everything is boosted by max. And even boosted to that max, I get a max of something like -36db at the end output. Regular guitar doesn't have this problem. How come, even each part of this giving like +12db, i'm losing so much volume? I can tell that the Drive on all the bass amps effects the volume greatly. But what if you want a clean bass tone and not a distorted one? I can kind of make the sound work right now if I put a bunch of compressors/volume plugins in my DAW after this, but I can't help but feel I'm doing this totally wrong. I've attached a picture if it helps and I can send more if needed. Any advice? Quote Link to comment Share on other sites More sharing options...
soundog Posted May 11, 2022 Share Posted May 11, 2022 Have you tried setting levels with NO Native blocks in the signal path? Set your input levels so you get a nice clean DI level. Make sure you don't overdrive the Native input setting (use -12dB for starters). You should have no problems getting a good output level into your DAW track unless there is something wrong in your hardware (bass, DI, Scarlett, or cables). After you get a good level, add an amp block only (with no cabinet). Start with the default settings and adjust. All still good? Then add a cabinet. Add blocks as needed, checking levels along the way. Troubleshooting: start simple, then add stuff. Let us know how it goes. 1 Quote Link to comment Share on other sites More sharing options...
Papanate Posted August 12, 2022 Share Posted August 12, 2022 Turn Off Helix and see if the Volume changes. Quote Link to comment Share on other sites More sharing options...
