brejna Posted May 14, 2022 Share Posted May 14, 2022 Hi, I got HX Stomp XL 2 weeks ago and today my 3 old son steped on it and damaged potentiometer/encoder (orange circle on pic). Where can I get spare part? I am in Europe Thanks in advance Brane Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 15, 2022 Share Posted May 15, 2022 On 5/14/2022 at 5:25 PM, brejna said: Hi, I got HX Stomp XL 2 weeks ago and today my 3 old son steped on it and damaged potentiometer/encoder (orange circle on pic). Where can I get spare part? I am in Europe Thanks in advance Brane Hi Brane, I don’t think that your unit will be covered by warranty in this instance, but it may be worth a try - it should be fit for purpose. You didn’t say which area of Europe you are in, but you can track down the nearest Line 6 authorised repair shop by entering your details into this page: https://line6.com/find/service_center/ Hope this helps/makes sense 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted May 15, 2022 Share Posted May 15, 2022 Point is, if you DIY, you will void the warranty for any future/further possible assistance. I would still let do the job to a Line6 licensed center, like Thomann, and keep the warranty alive as much as you can. ;) 1 Quote Link to comment Share on other sites More sharing options...
brejna Posted May 29, 2022 Author Share Posted May 29, 2022 Thanks for the responce. I contacted seller and they will try to organise everything. I really don't want to loose warranty. Best Brane 2 Quote Link to comment Share on other sites More sharing options...
jshearer3 Posted September 25, 2022 Share Posted September 25, 2022 Did you ever find this part? I'm likely in need of it and am trying to find information. Thanks! Quote Link to comment Share on other sites More sharing options...
sdelgado75 Posted January 20 Share Posted January 20 I think I found the correct part here https://www.fullcompass.com/prod/549803-line-6-24-12-0022-preset-encoder-for-helix My stomp is already out of warranty, so I'm going to give it a go. I'll let you know how it works out in week or so. Quote Link to comment Share on other sites More sharing options...
PierM Posted January 21 Share Posted January 21 On 1/21/2023 at 12:06 AM, sdelgado75 said: I think I found the correct part here https://www.fullcompass.com/prod/549803-line-6-24-12-0022-preset-encoder-for-helix My stomp is already out of warranty, so I'm going to give it a go. I'll let you know how it works out in week or so. Nope. Preset encoder is just the 24 mechanical impulse encoder that you use to browse presets. The high res parameter encoder which is soldered in the LCD board, is totally different. Quote Link to comment Share on other sites More sharing options...
batflash Posted January 22 Share Posted January 22 Can any one assist with finding the right encoder used for parameter changes on the HX Stomp? Or at least a set of specs for the encoder? I've got both a Helix and and HX stomp whose encoders are starting to wear. One whose push button collapsed internally last night. Thanks, J Quote Link to comment Share on other sites More sharing options...
PierM Posted January 22 Share Posted January 22 You won't find this part as official OEM from L6. They only distribute the entire display with the encoders as part of the same PCB. Contact British Audio and ask them if it's possible to order that part. If it's available to the market, they'll take care of it. Probably you'll have to buy more than one. https://britishaudio.com/pages/parts-request Or, just desolder the damaged one and check if it has a code to track it down in the general electronic parts market. Quote Link to comment Share on other sites More sharing options...
batflash Posted January 23 Share Posted January 23 Yeahhh, I ended up ordering some encoders off Digikey. Bournes 24PPR, no detent, Quadrature, Model/Part#: PEC11R-4015F-S0024-ND Can't say it'll work just yet. I'll post my experience on here when after I put them in. I wish more people would chime in about these sorts of things, other than the eye-rolling "That'll void your warranty"... which isn't any help. Thanks for the link, by the way. Thanks, J On 1/22/2023 at 12:29 PM, PierM said: You won't find this part as official OEM from L6. They only distribute the entire display with the encoders as part of the same PCB. Contact British Audio and ask them if it's possible to order that part. If it's available to the market, they'll take care of it. Probably you'll have to buy more than one. https://britishaudio.com/pages/parts-request Or, just desolder the damaged one and check if it has a code to track it down in the general electronic parts market. 1 Quote Link to comment Share on other sites More sharing options...
batflash Posted January 26 Share Posted January 26 For those following this thread and still looking. I found the part for the HX Stomp and it works great. Hope this helps. I also made a dedicated thread for the info. https://www.digikey.com/en/products/detail/bourns-inc/PEC11R-4015F-S0024/4499668?utm_medium=email&utm_source=oce&utm_campaign=4251_OCE23RT&utm_content=productdetail_US&utm_cid=3294583&so=79660503&mkt_tok=MDI4LVNYSy01MDcAAAGJeZwhRZlHpMczuFUKJJnBAI1cw3UpEiZQU9lj1m6djk3uIrKIfkkv702-v2drrxYburU4cGCOMTLMqBRAgNp_JnbIz01ZS88mDLPy61Z9 Quote Link to comment Share on other sites More sharing options...
