cain29671 Posted July 19, 2022 Share Posted July 19, 2022 Just started delving into the Looper. Have scanned several videos on Line 6 and Youtube about looping but none explain how to switch and overdub presets and/or snapshots. There are videos that have people doing it but none that explains how. I tried switching to a preset between an overdub and the looper just shuts off. I am however using the simple one switch mono. Can anyone explain how to overdub and record different presets/snapshots within the same loop session? 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 20, 2022 Share Posted July 20, 2022 All presets that you plan to use within the same Looper session must have the same Looper FX block (1-switch or 6-switch) in the preset. If you record a loop in one preset, then switch to a preset that has no (or a different) Looper block then the Looper stops working. If the preset you switch to has the appropriate Looper block then the Looper should continue to operate. Quote Link to comment Share on other sites More sharing options...
cain29671 Posted July 20, 2022 Author Share Posted July 20, 2022 That worked but in order to switch to a preset after recording a session the Mode switch has to be pressed to get back into Preset mode. I was trying to do this with snapshots but noticed a couple of the snapshots show the looper 'grayed' out. I know looper blocks are gray already but these are more of a dull gray where one snapshot is the standard bright gray. I tried removing blocks, thinking it was a resource issue but that didn't help. In fact I removed everything accept the amp and cab. Any idea on this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 20, 2022 Share Posted July 20, 2022 It’s not a DSP issue since the Looper exists in the preset. I expect it’s greyed out because the Looper can’t be bypassed/modified on a snapshot basis. You’re correct that it takes some foot tapping. Looper controls are only available in Stomp mode when the Looper block is selected and it’s controls are visible. To switch to another preset you need to leave Stomp mode, switch presets, then go back to Stomp mode in the new preset and select the Looper block to control it. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 20, 2022 Share Posted July 20, 2022 It’s not a DSP issue since the Looper exists in the preset. I expect it’s greyed out because the Looper can’t be bypassed/modified on a snapshot basis. You’re correct that it takes some foot tapping. Looper controls are only available in Stomp mode when the Looper block is selected and it’s controls are visible. To switch to another preset you need to leave Stomp mode, switch presets, then go back to Stomp mode in the new preset and select the Looper block to control it. You might be able to control things more easily using an external MIDI controller and sending the appropriate MIDI commands to the POD Go over USB. Details can be found in the USB/MIDI chapter of the Pod Go manual. I haven’t experimented with it but you might want to. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted July 20, 2022 Share Posted July 20, 2022 On 7/20/2022 at 3:41 PM, cain29671 said: That worked but in order to switch to a preset after recording a session the Mode switch has to be pressed to get back into Preset mode. I was trying to do this with snapshots but noticed a couple of the snapshots show the looper 'grayed' out. I know looper blocks are gray already but these are more of a dull gray where one snapshot is the standard bright gray. I tried removing blocks, thinking it was a resource issue but that didn't help. In fact I removed everything accept the amp and cab. Any idea on this? Check that you have each snapshot saved with the looper switched on. Quote Link to comment Share on other sites More sharing options...
BWTISME Posted August 4, 2022 Share Posted August 4, 2022 Hi using the 6 switch mono looper, I can easily record but how do I delete the loop to start again - I can overdub and then delete that but can’t seem to delete a loop entirely please help cheers Brian Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 4, 2022 Share Posted August 4, 2022 Quoting from the manual… ”If you press <the Record button> while loop playback is stopped, this will always record a new loop, and any previous recording will be discarded.” So to delete a loop you record a brief period of silence. Not sure this is a useful function though. What’s the value of deleting an existing recording? If a recorded loop exists and you don’t want to use it just don’t play it back. And if you want to record a new loop you perform the above action and record it. Another way to delete a loop is to turn the device off. Quote Link to comment Share on other sites More sharing options...
