dmcasas Posted July 24, 2022 Share Posted July 24, 2022 I've set up the same exact high-gain preset on Helix floor and Helix Native. When I plug my guitar into the floor I get a standard amount of noise. But when I plug the guitar into my audio interface to record with Native, the noise is much higher and I have to set the noise gate much higher, but the dry input signal is at a pretty similar level than the Helix Floor. I wonder if this is normal with audio interfaces. I'm using a Focusrite Scarlett 2i2 3rd Gen with the INST mode enabled when I plug guitar directly. Do you know any way to reduce the input noise from the interface? Thanks Quote Link to comment Share on other sites More sharing options...
josehdx Posted July 25, 2022 Share Posted July 25, 2022 Did you check the gain knob ln the audio interface? You need to reduce it to avoid clipping Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 25, 2022 Share Posted July 25, 2022 Also check the input level in Native itself... you will want the meter to hover around -18db for Native to react similar to the hardware (Helix). Quote Link to comment Share on other sites More sharing options...
amsdenj Posted July 27, 2022 Share Posted July 27, 2022 Make sure your audio interface is properly grounded, and you are using a high-Z input for your guitar. Also check the outputs of your computer and speakers. Noise could be created there if there's improper grounding or poor gain staging. The noise could be created in your interface's converters and preamps. I have no problems with Helix Native and noise, so I don't think there's an issue in the plugin. Quote Link to comment Share on other sites More sharing options...
