bshilkitus Posted August 9, 2022 Share Posted August 9, 2022 Can I use the MXR Tap Tempo switch with HX Stomp? If so, can someone PLEASE tell me how? I have spent hours trying to get this to work. Thanks in advance. Bill Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 10, 2022 Share Posted August 10, 2022 No. Did somebody tell you that this would work? EDIT: Yes, I didn't turn the knob far enough to see the FS4/5 Tap option. ALSO, you CAN control Tap Tempo externally using MIDI (CC#64 Value >63), and you COULD use the MXR switch with one of these: MIDI Solutions Footswitch Controller; General Purpose Input to MIDI for US $159. (maybe you can find one for less...) OR use this instead of the MXR for US $99 MIDI Baby — Disaster Area Designs This is a better plan, and can also be used WITH the MXR for other things. 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted August 10, 2022 Share Posted August 10, 2022 On 8/10/2022 at 12:28 AM, bshilkitus said: Can I use the MXR Tap Tempo switch with HX Stomp? If so, can someone PLEASE tell me how? I have spent hours trying to get this to work. Thanks in advance. Bill Yes. :) You can control Tap/Tuner with an external switch, via Global Settings. Depending if is it's a two switch pedal or a single switch, you'll be setting FS4 and/or FS5 as TAP/Tuner and it will work just fine. Holding the switch will kick into Tuner, tapping will set the tempo. If it's a single switch I believe you need to split the HX Stomp Footswitch port with a Y cable (TRS to TS/TS), as this port it's for two exp pedals or two FS. I do that with a cheap but very solid Ampero Switch, and works flawless. I can't see why you couldn't use that MXR Tap to do the same. As soon as it's a momentary FS, it should work once properly setup in the Globals. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 10, 2022 Share Posted August 10, 2022 On 8/10/2022 at 1:23 AM, PierM said: Yes. :) You can control Tap/Tuner with an external switch, via Global Settings. Depending if is it's a two switch pedal or a single switch, you'll be setting FS4 and/or FS5 as TAP/Tuner and it will work just fine. You're right! I didn't turn the knob far enough to see the FS4/5 Tap option. My bad! 1 1 Quote Link to comment Share on other sites More sharing options...
baaaacc Posted February 11, 2024 Share Posted February 11, 2024 HI! I'll join the conversation. I'm also looking for a switch/tap tempo (because they are really small and take up little space) that instead of acting as a tap tempo/tuner I can set it to change the presets, so as if it were an FS4. In your opinion is it possible, can it work? Or are they switches set just for tap tempo? I was looking in particular at source audio which costs even less than mxr https://www.thomann.de/it/source_audio_toolbox_tap_tempo_switch.htm Quote Link to comment Share on other sites More sharing options...
Sebbguitar Posted June 24, 2024 Share Posted June 24, 2024 Hi there! I managed to make my Stomp work right with a MXR tap, but I can't see the actual tempo flashing even it's set to display in the settings. Am I the only one experiencing this issue? Quote Link to comment Share on other sites More sharing options...
