Wondo100 Posted September 2, 2022 Share Posted September 2, 2022 Hello. I need to use the Helix for a small gig this weekend. They have a house system and will be using XLR out to mains. I do not have a monitor and was thinking of using a Fishman Loudbox as a monitor. There is an Aux in on the back of the amp but it is 1/4 stereo and if I come out of 1/4 out of Helix L it is going to be a mono out to the Fishman in. Is there a way that you would suggest doing this? I was thinking taking L and R out of Helix into a left and right in connector that has a stereo tip to go in to the Fishman but not sure if this will work. Thanks. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 2, 2022 Share Posted September 2, 2022 I don't see why it wouldn't work. Be sure to assign the Helix Volume knob to your 1/4" Out so you can use it to control the level to the LB without changing the signal to FOH. Quote Link to comment Share on other sites More sharing options...
Wondo100 Posted September 2, 2022 Author Share Posted September 2, 2022 Cool. I will work with this today. Big help as always @rd2rk Does this mean if big knob is set to 1/4 what does the XLR get set to since it will be running to FOH. Would I have signal path outs to multi? Quote Link to comment Share on other sites More sharing options...
