Circuschris Posted September 27, 2022 Share Posted September 27, 2022 On the Helix is it possible to use a footswitch to turn on a line out so, I can run to the monitors for solos? Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 1, 2022 Share Posted October 1, 2022 On 9/27/2022 at 6:16 AM, Circuschris said: On the Helix is it possible to use a footswitch to turn on a line out so, I can run to the monitors for solos? Hi, I’ve only just spotted your post - anyhow, with the Helix family of products theoretically you can assign anything to anything. You can make thing as complex, or as simple as you wish. Best place to start is the Helix Owner’s Manual https://line6.com/data/6/0a020a3f041b611d61cac763b/application/pdf/Helix 3.0 Owner's Manual - Rev F - English .pdf See page 45 “Snapshots”. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted October 1, 2022 Share Posted October 1, 2022 You can use a send block. Place it wherever you need in your chain. Bypass / un-bypass it during your solo snapshot. Or assign a foot switch to the send block. That way you can connect the send out to the PA using a 1/4 inch. 1 1 Quote Link to comment Share on other sites More sharing options...
