Separate Global Settings
a6strng
You could mimic this using the Command Center, which is allowing you to configure any switch in pretty much any way you like (so you could, say, as well have 8 snapshots and 2 plain switches) per patch, but you will completely lose the "plain" stomp mode, making this approach a no-go for me personally as I'm always using stomp mode to quickly access the most relevant patch parameters.
