palladinojt Posted October 9, 2022 Share Posted October 9, 2022 I made a boo-boo last night that I'm hoping you guys can tell me was a small one: I've got a DT25 112 that I run in 4CM with my Helix. When I play at home I usually connect a second 8-ohm speaker cab, so I connect that (as well as the internal speaker) into the two 4-ohm speaker outs. We played a gig last night; I did not bring the second cab with me but forgot to move the internal speaker over to an 8-ohm output jack. Our set was about 75 mins and I was running in Low-Volume mode (no idea if that makes any difference). The amp sounded great as always and made it through the gig fine (I didn't realize the gaffe until I was setting things up back at home this morning). Could I have potentially done any damage to the amp or is it OK? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted October 10, 2022 Share Posted October 10, 2022 Always check that the amp output matches the speaker load. From your Facebook posting, looks like you are okay this time. Quote Link to comment Share on other sites More sharing options...
