wooot Posted November 12, 2022 Share Posted November 12, 2022 Hi, I just upgraded from a Stomp to a Helix LT and now am trying to build some basic patches for me. Since I play mostly Tele and Strat, I always liked what the Thorpy Dane does with a clean amp for the Tele. Is there a drive pedal (or several) in the Helix, that could get me somewhat close to that? Cheers! Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted November 12, 2022 Share Posted November 12, 2022 Use google and see if you can get some idea of the configuration amp/pedals/etc used and then simulate it on the Helix. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 12, 2022 Share Posted November 12, 2022 On 11/12/2022 at 6:45 PM, wooot said: Hi, I just upgraded from a Stomp to a Helix LT and now am trying to build some basic patches for me. Since I play mostly Tele and Strat, I always liked what the Thorpy Dane does with a clean amp for the Tele. Is there a drive pedal (or several) in the Helix, that could get me somewhat close to that? Cheers! Hi, I guess you are referring to the gizmo that Adrian Thorpe designed for Danish Pete which is a clean boost into overdrive box of tricks. There is quite a good description of what it does in this review (link below) - take notes, and build your own from the many, many options available in the dual path Helix LT. Play around until you get something you like, it’s highly unlikely that you will break anything, but you may damage your hearing. https://www.musicradar.com/reviews/thorpy-fx-the-dane Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
wooot Posted November 13, 2022 Author Share Posted November 13, 2022 On 11/12/2022 at 11:18 PM, datacommando said: Hi, I guess you are referring to the gizmo that Adrian Thorpe designed for Danish Pete which is a clean boost into overdrive box of tricks. There is quite a good description of what it does in this review (link below) - take notes, and build your own from the many, many options available in the dual path Helix LT. Play around until you get something you like, it’s highly unlikely that you will break anything, but you may damage your hearing. https://www.musicradar.com/reviews/thorpy-fx-the-dane Hope this helps/makes sense. Tanks, thats helpful! 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 13, 2022 Share Posted November 13, 2022 I had to go listen to a few demo's.... it's a great sounding pedal. To be honest, it's sounds like a natural boost/overdrive which is where I lean to the Tee-mah (Timmy) in the Helix. The trick is to keep the gain relatively low and experiment with the clipping modes and tone controls. 2 Quote Link to comment Share on other sites More sharing options...
