sornord Posted November 18, 2022 Share Posted November 18, 2022 I've been trying to get spare hardware for my recently purchased Variaxes (a JTV-59 and a 700 Bass.) I've been able to sort out I can use the bass's XPS-DI with the JTV-59. I'd like one, CURRENTLY SUPPORTED, power source for BOTH my variaxes. Helix equipment is too expensive. Are there other, older products that will fit this bill, perhaps the Line 6 Pod XT Live? I can find those used for reasonable prices. Still looking for VDI to USB adaptors and JTV batteries too, by the way. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 18, 2022 Share Posted November 18, 2022 Each Variax is an iteration of different technologies. The 700 Bass came out with the original Variax (the one with no pickups). If you just want power for them, you'll need to find an XPS-DI which are not made anymore. As you found it will work for both. You'll have to find a used one. Fortunately the bass uses AA batteries so if you invest in some rechargable ones you'll be good. You do need 6 (or 12 if you want to have another bunch to stand by, fully charged) so it's a little pricey initially but they last a long time. There's a thread that addresses the JTV power supply and in it, someone created and internal power supply for it using a DC-DC switching power supply here's a pic Here's the thread it's in from the JTV Variax forum. On warning, if you are using the VDI to power your Variax from a Line 6 modeler, DO NOT also use the 1/4" out at the same time. It can work but there is a great potential for it to brick your Variax. Hope this helps. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 21, 2022 Share Posted November 21, 2022 This was posted recently at the JTV forum on the thread I previously linked. Looks good. I think I'll get one. WARNING! Non-Line6 products will void your warranty! OK, now that's out of the way, I recently purchased a Variax 300 and needed a power supply. I bought one from here https://www.ebay.ca/itm/394012304176?hash=item5bbcf6a330:g:CSIAAOSwtuZiZrJg&amdata=enc%3AAQAHAAAAoMguJeGZ8cSNGbIf5KOmOE4pfFik9zonkIuKO7ufWs2NRG5ikt6HG1DtQ3pnD6t%2F%2BtSKKvcn0OskIS%2B7aEV0hkx9z8aCJsHnqAYwKPYS%2FxS6b4KciT7CmPQPTfwS%2FvTWz3ihcZzWjorU81BqdVQ2bNc7wnP1dsk%2BT38Idw4aO7cyZ2PD94KVcX%2F7LuHhWtX8rAoc47VUdIkC9tXJ06MRyro%3D|tkp%3ABk9SR5bb9r2SYQ and it works like a charm. Also, his pedal has a switch to change from 9vc to 7.5 for the newer ones. Totally recommend his pedal! Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2022 Share Posted November 21, 2022 On 11/17/2022 at 10:43 PM, sornord said: I've been trying to get spare hardware for my recently purchased Variaxes (a JTV-59 and a 700 Bass.) I've been able to sort out I can use the bass's XPS-DI with the JTV-59. I'd like one, CURRENTLY SUPPORTED, power source for BOTH my variaxes. Helix equipment is too expensive. Are there other, older products that will fit this bill, perhaps the Line 6 Pod XT Live? I can find those used for reasonable prices. Still looking for VDI to USB adaptors and JTV batteries too, by the way. A POD XT Live with a VDI cable/connection will power both your Variaxes. It will probably also provide additional control over the 700 Bass, but will not fully support your JTV (no alternate tuning control, perhaps limited model selection control). The XT Live is currently supported by Line 6 as a Legacy product under the following terms: https://line6.com/support/announcement/108-limited-support-of-legacy-products/ Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 21, 2022 Share Posted November 21, 2022 On 11/21/2022 at 6:02 AM, silverhead said: A POD XT Live with a VDI cable/connection will power both your Variaxes. It will probably also provide additional control over the 700 Bass, but will not fully support your JTV (no alternate tuning control, perhaps limited model selection control). The XT Live is currently supported by Line 6 as a Legacy product under the following terms: https://line6.com/support/announcement/108-limited-support-of-legacy-products/ Just to be clear, you do not want to use the 1/4" output on your guitar while using the VDI cable to power it. I know this to be true with the JTV. Not as sure about the 700 Bass but I believe it was recommended not to do this with this version of Variax as well. You would have to use an FX send to get your Variax signal out of the XT from being powered by the XT. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2022 Share Posted November 21, 2022 On 11/21/2022 at 9:16 AM, brue58ski said: …. You would have to use an FX send to get your Variax signal out of the XT from being powered by the XT. Why not just use the XT Main output? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2022 Share Posted November 21, 2022 On 11/21/2022 at 12:42 PM, silverhead said: Why not just use the XT Main output (with no processing in the signal path)? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 21, 2022 Share Posted November 21, 2022 On 11/21/2022 at 9:42 AM, silverhead said: Why not just use the XT Main output? I believe the send has an instrument level out option is why I said that. I suppose the 1/4" would too. I don't have mine anymore. Quote Link to comment Share on other sites More sharing options...
sornord Posted December 1, 2022 Author Share Posted December 1, 2022 Got an X3 Live a couple of days ago and works great with my JTV. Will try it with the bass in a day or two. Tnx for your input. I also bought a couple of XPS Minis so am good to go power-wise I think. This X3 looks like a beast! Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 1, 2022 Share Posted December 1, 2022 My first Line 6 product was an X3 Live, back in 2009 when it was the flagship. I followed that soon after with a Variax 300. Loved them both, especially together. Have Fun! Quote Link to comment Share on other sites More sharing options...
brue58ski Posted December 2, 2022 Share Posted December 2, 2022 On 12/1/2022 at 2:50 PM, sornord said: Got an X3 Live a couple of days ago and works great with my JTV. Will try it with the bass in a day or two. Tnx for your input. I also bought a couple of XPS Minis so am good to go power-wise I think. This X3 looks like a beast! After the Helix, Fractal, Kemper, etc. and all of the iterations of the latest in modelling, one of my recommendations would definitely be the X3. You can get in cheap and it has all of the old (but good) modelling and is totally the equivalent of two POD XT's side by side in one package. Quote Link to comment Share on other sites More sharing options...
