Midi Expression Pedal with HX Stomp
Biggers11
I was wondering if it would be possible to use a midi expression pedal to control the Wah and Volume functions of the HX Stomp. I am specifically looking at getting a Boss EV 1 for this. Has anyone had any experience doing this ? I am currently using the EXP 1/2 out for a dual footswitch to change between patches and I wanted to also add an expression pedal to this setup.
AFAIK the Boss EV1 is a wireless (Bluetooth) pedal, and the USB function is used to control music software (DAW) on a Mac or PC. The last option is MIDI which you could connect to the HX Stomp and program it to be used as an Expression Pedal with MIDI CC#1 or CC#2. I have not personally tried this, but you could check with the retailer to see if it is feasible, or get the pedal on sale or return if it doesn't works expected.
Hope this helps/makes sense.
EV1 is fine, but you'd need a BLE adaper for the HX Stomp, like a Widi Master, or a Widi Jack.
pedal also offer a TRS MIDI OUT, but at that price that pedal make sense only if tou really want wireless midi, imho.
For a similar price (wired MIDI), but much better construction than EV1, there is the EX3 from BeatBars; https://beatbars.com/it/home.html
