Help!! Constant reverb on every sound
wilsunband2022
Hey guys!
I have a problem with my Helix LT. Since i've got the HX edit app yesterday to update my Helix, there is a constant reverb on every sound. I even did a factory reset / global reset and everything, deleted all presets but the reverb is still there. When I connect the Helix with my Laptop and watch a youtube video , the youtube video has also the same reverb. Has anyone an idea how fix that problem?
Thanks a lot
Manuel
If you use a DAW, turn off input monitoring... If you don't use a DAW, I suspect there are audio settings in the OS that create the same problem. To test if it's the Helix or the computer... simply unplug the USB cable. If the unwanted reverb goes away the problem is in the computer, look there to solve it not the Helix.
