wilsunband2022 Posted December 10, 2022 Share Posted December 10, 2022 Hey guys! I have a problem with my Helix LT. Since i've got the HX edit app yesterday to update my Helix, there is a constant reverb on every sound. I even did a factory reset / global reset and everything, deleted all presets but the reverb is still there. When I connect the Helix with my Laptop and watch a youtube video , the youtube video has also the same reverb. Has anyone an idea how fix that problem? Thanks a lot Manuel Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 11, 2022 Share Posted December 11, 2022 How are you monitoring the sound? Headphones directly to Helix? External speakers? PA? Is it possible the reverb is coming from another piece of equipment? Quote Link to comment Share on other sites More sharing options...
codamedia Posted December 11, 2022 Share Posted December 11, 2022 If you use a DAW, turn off input monitoring... If you don't use a DAW, I suspect there are audio settings in the OS that create the same problem. To test if it's the Helix or the computer... simply unplug the USB cable. If the unwanted reverb goes away the problem is in the computer, look there to solve it not the Helix. Quote Link to comment Share on other sites More sharing options...
amsdenj Posted December 11, 2022 Share Posted December 11, 2022 Do you have any room ambience in you (legacy) cab models? Quote Link to comment Share on other sites More sharing options...
