Dpruett14 Posted December 16, 2022 Share Posted December 16, 2022 Hello all, Wanted to see if you all could help me with this...so I typically use my stomp with just one expression pedal with a TRS Cable, and all works great. I attempted today to use a second EXP in conjunction with the first one, using a Y-split cable (tip & sleeve into one exp pedal, and ring & sleeve into the other). To my surprise, this didn't work the way I expected. Using either exp pedal going one full sweep starting from heel to then toe position, the stomp reads 0% to 100% only halfway through the sweep, then goes back down to 0%...at the toe position..?! So for one motion of my foot from heel to toe, the stomp goes 0% to 100% to 0%. I am baffled to say the least and I have tried changing every settings for EXP in the Global Settings but he has yet worked. If you guys have had experience with this issue, please let me know. Thanks Quote Link to comment Share on other sites More sharing options...
