change amp in stompmode
lcmorgado
I there
is possible to change the amp in pod go in stomp mode?
i want to assign a footswich to change the amp. For example i want to have a clean sound amp and a distortion amp, with the same pedals in stomp mode.
 in helix we can do it, is possible in Pod go?
Regards
Luis
…. in helix we can do it, is possible in Pod go?
 No, this is not possible in the POD Go. You need to manually change the amp in Edit View.
  • 2 weeks later...
On 12/30/2022 at 3:11 PM, SiCantwell said:
But you can change amp settings like drive. It's easy to find amps that sound good clean and dirty. Play around with channel volume vs. master volume.
This - and you can also change the mic type in the stock cabs & you can assign the change to one of the footswitches.  And whilst you can't change the stock cabinet in the same patch, if you are using IR's you can change these in the same patch.  These options can make a big difference to your tones.
