BertrandA Posted January 6, 2023 Share Posted January 6, 2023 Hello everybody, On HX STOMP, is it possible to create an effect allowing to detune only one guitar string ? For me only E bass to B and I don't use chords, only notes. Using pitch with threshold filter ? i don't know... Thank you in advance for your opinions or tips. Cordially. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 6, 2023 Share Posted January 6, 2023 No, at least in terms of affecting only one string. However, you say you only play notes, not chords. Depending on your tempo and foot-tapping accuracy you may be able to use a Pitch effect that detunes all strings the appropriate amount. Then you turn that FX block on/off as required each time you play the single note that you want detuned. Not sure how practical this would be but it is a technical solution. Quote Link to comment Share on other sites More sharing options...
BertrandA Posted January 6, 2023 Author Share Posted January 6, 2023 It would have been too beautiful ! Thanks a lot. Good idea your proposal but impossible for the track i play. So i really need a second guitar. Quote Link to comment Share on other sites More sharing options...
theElevators Posted January 6, 2023 Share Posted January 6, 2023 Only on a Variax guitar/bass you can change the tuning. Otherwise, as others have mentioned, there is no way to downtune only one string on a conventional guitar. Try the poly capo feature, however. You may be able to rework your songs/parts to be able to play in low B-tuning. Here's a video where I show how to create low tuning of the entire guitar digitally. Quote Link to comment Share on other sites More sharing options...
