GazzaBloom Posted March 25, 2014 Share Posted March 25, 2014 How are you guys configuring the mixer when connecting your POD HD to your single DT amps? What's the best setting to match the default DT amp models already loaded in the amp? Do you hard Pan left and right as default or centre the pan controls? Gazza Quote Link to comment Share on other sites More sharing options...
radatats Posted March 25, 2014 Share Posted March 25, 2014 I have done both and haven't found a big difference except centered raises the volume a bit. Either is fine since it all goes to mono at the amp anyways... Try them both, maybe with certain effects one is more useful than the other... 1 Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted April 2, 2014 Share Posted April 2, 2014 Confirming Radats, center versus hard right/left makes a difference of 6dB for the mixer output signal. If you have effects after the mixer you need to be careful not to drive them into effect produced soft clipping/compression/distortion. Found in the past that you want to stay below peaks of -12dBFS (measured via USB) to avoid even a hint of compression/distortion. That is not to say that you can't use this side effect if it suites your needs and ears ;-) ... 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 3, 2014 Share Posted April 3, 2014 Don't forget you can move the mixer to the end of the chain. Confirming Radats, center versus hard right/left makes a difference of 6dB for the mixer output signal. If you have effects after the mixer you need to be careful not to drive them into effect produced soft clipping/compression/distortion. Found in the past that you want to stay below peaks of -12dBFS (measured via USB) to avoid even a hint of compression/distortion. That is not to say that you can't use this side effect if it suites your needs and ears ;-) ... Right on and to the point. Thumbs Up. Quote Link to comment Share on other sites More sharing options...
