rudomat Posted January 26, 2023 Share Posted January 26, 2023 hi, is it possible on the LT to have the rear expression 2 jack controll my amps channels (via TRS cable) and have the onboard pedal control the wah (pedal1) and volume (pedal2)...? i try to achieve this...but as soon as i plug the TRS cable into the rear expr.2 jack, the onboard expression pedal won`t change between pedal1 and 2 via the toe switch....isn't that possible...? thanks! Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 29, 2023 Share Posted January 29, 2023 Global Settings > Preferences > "EXP2/EXT AMP" (Page 66 in the V3 Manual) Set that option to "EXT AMP" (external amp) That leaves the built in EXP as 1&2 with the toe switch. Quote Link to comment Share on other sites More sharing options...
roryburns Posted January 30, 2023 Share Posted January 30, 2023 GT-1: WAH Control Using External Expression Pedal EXP2 Control the WAH with your external EXPRESSION PEDAL connected with 1/4" TRS cable to EXP2 Input Jack. (Use BOSS expression pedal: EV-5, EV-30, FV-500H or other). EXTERNAL WAH SET UP FOR EXP 2 AND VOL FOR EXP 1 FOR THE GT-1: 1. Press [MEMORY EDIT] to enter into Effects Chain View. 2. Use KNOB 1 to select PDL, should be highlighted - press [ENTER] - Use KNOB 3 to turn PDL ON. 3. With PDL selected - Turn PDL ON with KNOB 3, press [ENTER] - Select WAH TYPE - "CRYBABY" or desired WAH TYPE and any WAH PARAMETERS - Press [EXIT] to return to Effects Chain View. In EFFECTS CHAIN VIEW, 4. Use KNOB 1 to select EX 1 (Expression 1) - press [ENTER] to enter EXP 1 MENU - use KNOB 1 and set to FOOT VOL - Press [EXIT] - to return to Effects Chain View. In EFFECTS CHAIN VIEW, 5. Use KNOB 1 to select EX 2 (Expression 2) - press [ENTER] - use KNOB 1 and set FUNCTION to OFF - Press [EXIT] - to return to Effects Chain View. In EFFECTS CHAIN VIEW, 6. Use KNOB 1 to select A1 (Assign 1) - press [ENTER] - use KNOB 1 to set ASSIGN to ON - use KNOB 2 to set SOURCE to EXP 2 (External Expression Pedal 2) - use KNOB 3 set the MODE to MOMENTARY. 7. Press ENTER to change to ASSIGN 1, PAGE 2 - use KNOB 1 to set CATEGORY to PEDAL FX - use KNOB 2 to set TARGET to WAHPDPOS (WAH Pedal Position) - Press [EXIT] - to return to Effects Chain View. 8. WRITE/SAVE your setting, Press [EXIT] + [ENTER] to the WRITE MENU - use KNOB 1 to select WRITE - use KNOB 1 to choose a preferred USER PATCH LOCATION to WRITE/SAVE your current PATCH to - press [ENTER] - Rename your PATCH if desired - press [ENTER] and select a GENRE for your patch, use KNOB 1 for GENRE 1 and use KNOB 3 for GENRE 2 - press [ENTER] again to finally WRITE/SAVE your PATCH setting changes. 9. Make sure that your EXTERNAL EXPRESSION PEDAL MIN-MAX RANGE KNOB is set to ZERO (0) so you have full range sweep with the WAH. 10. Test your EXP 2 External WAH. Make sure you PRESS TOE DOWN on your on board EXPRESSION PEDAL 1 to ACTIVATE and TURN ON PEDAL FX LED and WAH. Test the EXPRESSION PEDAL 2 external for audible check of the WAH EFFECT. NOTE: To visually check the functionality of the EXP 2 PEDAL - In EFFECTS CHAIN VIEW - use KNOB 1 to select PDL - press [ENTER] twice to PEDAL FX PAGE 2 - use the EXP 2 EXTERNAL PEDAL and visually check the PDL POS values are changing from 0 to 100. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 30, 2023 Share Posted January 30, 2023 @roryburns... I think the OP has a Line 6 Helix LT, not a BOSS GT-1. 1 Quote Link to comment Share on other sites More sharing options...
