Failed to load preset - Could not decrypt the asset. [code -1116]
pledge
On 2/13/2023 at 1:20 PM, pledge said:
Hi, i'm using Logic Pro and Helix Native, suddenly when i open the plug-in i got this error "Failed to load preset - Could not decrypt the asset. [code -1116]"
A little search would have revealed this:-
Hope this helps/makes sense.
  • 5 months later...
@line6 This is not acceptable now.
I have been a loyal customer for more than 20 years now. Every time I want to make music, I am blocked by this. Instead of composing, I am struggling with this problem.
I can't use my presets, even factory ones, I can't save my presets, and I have to restore to factory default again ? Losing all my presets ?
This is NON SENSE. I am fed up !
FIX THIS !!
FIX THIS !!
This thread seems to have a solution
FIX THIS !!
You don’t mention what computer and OS you are having this issue with?
You could check this tread for a possible solution.
