Punkyboy Posted February 18 Share Posted February 18 Hello I want to know Can I with the Hx stomp do exactly the same as the Helix LT? The same split system ? Using the same number of blocks? Split into 4 lines? Do i have the same amps, cabs, fx etc... Is there something missing in the HX stomp compare with the helix (behalve the variax input)? tx Quote Link to comment Share on other sites More sharing options...
rwandering Posted February 19 Share Posted February 19 The answer is no, yes (if I interpret the question correctly), no, no, and yes. The Helix LT has more I/O, DSP, more blocks, more paths, more presets (storage), more snapshots per preset, but all of the same effects, amps, etc. A really helpful place to see the differences between them is in Line6's own comparison chart. Line_6_Processor_Comparison_Chart.pdf (line6.com) I have both (though I wish I had the floor, not the LT). The only reason that I have the HX Stomp is that it is more portable and can be battery operated. For example, I can bring it onstage for an Open Mic (easily). I can put it in a suitcase if travelling (noting I carry a travel guitar in those cases). I can bring it into a small practice room where the Helix LT may just seem to big. 2 Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted February 19 Author Share Posted February 19 Thank you very much ! I was looking for the HX Stomp or Headrush MX5 I know more about with thiscomparison TX Quote Link to comment Share on other sites More sharing options...
codamedia Posted February 19 Share Posted February 19 On 2/18/2023 at 3:08 PM, Punkyboy said: Can I with the Hx stomp do exactly the same as the Helix LT? It's half an LT, with additional limitations. The tones are the same... but you cannot get as much out of a single preset. On 2/18/2023 at 3:08 PM, Punkyboy said: The same split system ? The split blocks are the same, but you don't have the same number of paths. On 2/18/2023 at 3:08 PM, Punkyboy said: Using the same number of blocks? No. The LT has up to 32 blocks, the Stomp has 8. On 2/18/2023 at 3:08 PM, Punkyboy said: Split into 4 lines? Nope.... You get one parallel split... ie: 2 lines. On 2/18/2023 at 3:08 PM, Punkyboy said: Do i have the same amps, cabs, fx etc... For the most part... YES. Off the top of my head I can't think of any exceptions, but there could be. 1 1 Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted February 19 Author Share Posted February 19 Thanks codamedia 1 Quote Link to comment Share on other sites More sharing options...
