Newbie Help
Hi guys. I have just bought one of the original? 500 series Variax in spanking candy red and want to start using the Workbench to tweak some sounds. I have an Imac running Catalina 10.15.7
Have I got the right download? I tells me it needs OS X 10.5 or above which I have??
John
Looks like it goes to 10.8 Mountain Lion. Catalina is too far ahead for it.
And a 500 Electric is not compatible with Workbench HD, too many differences
between old and new models formats.
Use an older computer to interface with a 500 that uses OS compatible with old Workbench.
This issue is discussed in other threads here. The old legacy Workbench is only reliable on older systems. I use Macs and tried using emulation software running Mountain Lion on a Catalina-based Mac, but that didn't work. I ended up using a very old Macbook (one of the white plastic ones) running Mountain Lion, and use it now for running older software for older equipment such as a Variax acoustic 700. Its a workaround for sure, but that's your best solution. If you don't have an old clunker Macbook, check Craigslist or Ebay. Macbook 2013 looks like thet're selling for around $120.
This is the main drawback of Variax guitars. If you need to edit their sounds, you're sheet out of luck over time. A "real" guitar can be passed on for generations!
