Nooxx Posted March 1, 2023 Share Posted March 1, 2023 It sounds like something is rattling around inside my helix, when I tilt it I can hear it moving around inside the unit. Is this cause for alarm? I just shipped it across the country for a gig, since its still working I don't think its worth it to file a UPS claim yet. Has this happened to anyone? I can't have it shorting out on me during a gig. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 1, 2023 Share Posted March 1, 2023 If there’s rattling there’s something loose. It’s a ticking time bomb before it may land in a spot that will cause a short circuit when the device is powered on. Get it resolved. If it’s still under warranty take it to an authorized service centre. If not, start investigating how to take the device apart bit by bit to find the loose screw or whatever. Or, leave things as they are until it shorts out…. which it may never do, but…… 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted March 1, 2023 Share Posted March 1, 2023 Just open the unit and remove the thing. It could be a bolt, or a bit from the XLR lock systems...or any other metal bit that could easily short something on the PCB and damage the unit. Easy to solve. ;) 1 Quote Link to comment Share on other sites More sharing options...
Nooxx Posted March 1, 2023 Author Share Posted March 1, 2023 On 3/1/2023 at 6:06 AM, PierM said: Just open the unit and remove the thing. It could be a bolt, or a bit from the XLR lock systems...or any other metal bit that could easily short something on the PCB and damage the unit. Easy to solve. ;) Does this void the warranty? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 1, 2023 Share Posted March 1, 2023 Technically yes. That's why I suggested the service center. On the other hand the risk may be low unless there are several layers of disassembly and you're unable to put things back together properly. Only one way to find out I guess. What sort of risk-taker are you? 2 Quote Link to comment Share on other sites More sharing options...
PierM Posted March 1, 2023 Share Posted March 1, 2023 On 3/1/2023 at 4:12 PM, Nooxx said: Does this void the warranty? Yep, but shorting a condenser (this is risky even when unit is turned off) or a diode, or a Sharc...would be probably worse. :) 1 Quote Link to comment Share on other sites More sharing options...
