YaBoiNate Posted March 23, 2023 Share Posted March 23, 2023 Can you download and use patches from lets say the 3.0 or 3.15 firmware versions even if your HX Stomp is updated to the 3.5 or newest firmware versions? Also the case for IR's and other effects? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 24, 2023 Share Posted March 24, 2023 Yes. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 27, 2023 Share Posted March 27, 2023 What you should do is run the Rebuild Presets Power On Routine immediately after you import any such older firmware Presets to assure that they are updated to be compliant with the current firmware you are running on your Helix or HX family device. Check HelixHelp.com for the appropriate Power On sequence for your device. The Rebuild Presets procedure is the one you want to run. 1 Quote Link to comment Share on other sites More sharing options...
