rubenmalmsteen Posted April 8, 2023 Share Posted April 8, 2023 I was looking for a way to increase the recording volume when channel 3/4 is selected, to later reamp. The problem is that the signal it sends is so low that it seems to have a kind of noise gate, and many details such as string noises, slides and other details are lost. It is not solved by normalizing the recorded track. It would be nice if they fixed it in a next update. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 8, 2023 Share Posted April 8, 2023 This is the dry signal straight from your guitar with no gain, so, yes, it will be very low. But that’s what you want for the purpose of re-amping. Quote Link to comment Share on other sites More sharing options...
ewendland Posted March 20, 2024 Share Posted March 20, 2024 I've noticed this, and I understand that it's the direct signal from the guitar. I was having a different issue, mainly that when the DAW sends the DI signal back through the POD, the output is much lower than the original signal so I would lose a ton of gain, as if I backed off my volume knob on my guitar. I've been able to solve this is by moving my pickups closer to the strings to get more direct signal and then adjusting the channel volume in the preset to match. Would be nice if there was a way to adjust the volume of the direct signal, but I get that adding any gain there might make it worse. Quote Link to comment Share on other sites More sharing options...
