rockerroser Posted April 12, 2023 Share Posted April 12, 2023 i want the line 6 helix lt built in pedal for volume control only and exp 2 to be controlled by a mission sp1-6 helix foot pedal to control wah only how do i set this up Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 12, 2023 Share Posted April 12, 2023 Simply connect your external pedal to the EXP2 jack on the rear panel of the LT. Use the Controller Assign feature to assign EXP1 (the onboard pedal) and EXP2 (external pedal) to your preferred parameters (Vol level and Wah level). See manual for further details re: Controller Assign feature if desired. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 12, 2023 Share Posted April 12, 2023 On 4/12/2023 at 1:28 AM, rockerroser said: i want the line 6 helix lt built in pedal for volume control only and exp 2 to be controlled by a mission sp1-6 helix foot pedal to control wah only how do i set this up Hi, You could try the suggestion supplied by @silverhead in the post above, but IIRC the Mission SP1-6H Line 6 is designed to be used with the Rack, Rack Controller, HX Stomp, HX Stomp XL and DL4 Mk2 units specifically. Mission recommend the Mission EP1-L6 pedal for use with a TS cable, and Line 6 specific pedals should be used with Line 6 devices. Check here: https://missionengineering.com/shop/sp1-l6h/ https://missionengineering.com/shop/ep1-l6-line-6/ Once you know what pedal is required the consult the Helix LT owner's Manual regarding settings - https://line6.com/data/6/0a020a3f18374611d5dffd3a45/application/pdf/Helix LT 3.0 Owner's Manual - Rev D - English .pdf Hope this helps/makes sense. 2 Quote Link to comment Share on other sites More sharing options...
