themetallikid Posted April 14, 2023 Share Posted April 14, 2023 Will we ever be able to (is if possible?) to reorder the Amp list (or other effects) in an order that makes more sense to our personal uses? Meaning put all my cleanish amps up towards the top and the Toneballz Metal amps towards the bottom? I have gone through and dialed in the amp/cab blocks how I like *most of the amps. While I get the 'thats what favorites are for' argument...I think this is more of the user default setting than a favorite. It'd be nice to do that. While I have dialed in the amps how I like them, my clean amps are all over and mixed in with breakup type sounds and such. Didnt know if the ability to drag and drop order (similar to preset organization) messes with any sort of internal memory programming. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 14, 2023 Share Posted April 14, 2023 I know you get the '.... favorites...' argument. Personally I've always wondered what the difference is, to the user, between User Default and Favorite. What's the actual difference from the user perspective other than, I suppose, being able to define two 'favorites' (which you can already do by using different model names)? In other words, is there any actual value in being able to do what you want? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 14, 2023 Share Posted April 14, 2023 Yes, that’s the idea of Favorites. It’s also the idea behind the User Default feature, which allows you to overwrite the factory default settings of the amp as it appears in the Amp model (not Favorites) list. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted April 14, 2023 Author Share Posted April 14, 2023 On 4/14/2023 at 9:59 AM, silverhead said: I know you get the '.... favorites...' argument. Personally I've always wondered what the difference is, to the user, between User Default and Favorite. What's the actual difference from the user perspective other than, I suppose, being able to define two 'favorites' (which you can already do by using different model names)? In other words, is there any actual value in being able to do what you want? The advantage for ME (maybe others) would be a couple things.....mainly stemming from some amps just do certain things well and stay in their lane with that. Some amps are versatile, sure. Sometimes the difference between amps that do the same thing is just a 'feel' thing. They might be in the same ballpark gain/tone/vibe sense, but the playing feel may be different. To ME, it would be easier to find similar amps if I had the Recto near the Badonk (just one example, those amps i'm familiar with. However, there are amps I do not have real world experience with nor much knowledge of, I would love to dial in the User Default, and then move that amp where I think it fits sonically in MY amp list. Yes I can do that with favorites, but I prefer to keep my User Favorites as specific instances of the amps. For example, I do a Stone Temple Pilots tribute, and have my core preset blocks saved as 'STP XXXX'. Thus when we add a new song, I can very quickly just go to my favorites and in about 15 seconds, draw up a preset that addresses the songs tone needs. I spend more time programming the command center for a performance then the actual tones.... ....However, I am in a new variety cover band that is just starting up. I do not know the full spectrum of songs we are going to be doing, we have a girl singer, so that helps widen the variance. With that in mind, There are lots of Clean/Edge of breakup/Pushed style amps in there that are sorta scattered in the list a bit. It would benefit me to set the user defaults (which I've done) but then be able to organize similar amps next to each other. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 14, 2023 Share Posted April 14, 2023 Thanks for clarifying. Makes sense to me. Have you opened an Ideascale item for this? Quote Link to comment Share on other sites More sharing options...
themetallikid Posted April 14, 2023 Author Share Posted April 14, 2023 On 4/14/2023 at 2:44 PM, silverhead said: Thanks for clarifying. Makes sense to me. Have you opened an Ideascale item for this? I have not, maybe tonight, unless someone else wants to. I just wanted to make sure my idea wasnt missing an already existent feature. Quote Link to comment Share on other sites More sharing options...
