Uninstall Helix Native - Mac M1 Ventura 13.3.1 - HXN 3.60
furym
I tried looking where the manual says in Library>Audio>Plugins but all the folders in there are empty. Where does HXN actually install these days? How do I go about deleting it after a trial ends?
MacBook Air M1 Ventura 13.3.1 - HXN 3.60
You do realise that your Mac has more than one Library folder? Check the one that is usually hidden.
https://www.drbuho.com/how-to/show-hidden-files-mac
also check
Knowledge Base > Recording > Helix Native
Best thing for you to do is read the Helix Native Pilot's Guide and on page 6 you will find the detailed info you require, under the heading
"Removing Helix Native".
http://uk.line6.com/support/manuals/helix-native/
Good luck.
Hope this helps/makes sense.
On 4/26/2023 at 6:49 AM, datacommando said:
also check
Good luck.
Thank you, but those were the first things I tried. Option allows access to that Library and when I follow the paths described in the manual, none of the files are in those locations. A search in Finder (with hidden files selected) also does not find those file names.
