CJ-Remis Posted May 30, 2023 Share Posted May 30, 2023 Hello everyone, I have a HX Stomp that I purchased in 2019. I've tried to register it but I can't find the serial number. Could you please tell me where can I find it? Thanks in advance. CJ. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 30, 2023 Share Posted May 30, 2023 It should be on the bottom of the device. The manual shows pictures of every surface except the bottom and it isn’t on any of those surfaces, so….. 1 1 Quote Link to comment Share on other sites More sharing options...
CJ-Remis Posted May 30, 2023 Author Share Posted May 30, 2023 Thanks a lot! Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 30, 2023 Share Posted May 30, 2023 I found this Hi All, so to save some stress and trouble - YES, YOU CAN ALWAYS LOOK UP SERIAL NUMBER ON THE DISPLAY OF THE HX STOMP. What you need to do is: -switch off your HX Stomp or Stomp XL -press and hold encoder 3 (the third knob the right under the display) -switch on your HX Stomp XL -you should see the serialnumber displayed This is what I got from Line6 support and I just tested this solution as I was missing the serial number sticker as well. Happy product registration and shopping for discounted Native plugin! :) 4 Quote Link to comment Share on other sites More sharing options...
connorball1h Posted June 25, 2024 Share Posted June 25, 2024 On 5/30/2023 at 2:47 PM, brue58ski said: I found this Hi All, so to save some stress and trouble - YES, YOU CAN ALWAYS LOOK UP SERIAL NUMBER ON THE DISPLAY OF THE HX STOMP. What you need to do is: -switch off your HX Stomp or Stomp XL -press and hold encoder 3 (the third knob the right under the display) -switch on your HX Stomp XL -you should see the serialnumber displayed This is what I got from Line6 support and I just tested this solution as I was missing the serial number sticker as well. Happy product registration and shopping for discounted Native plugin! :) The user manual or warranty card may also contain the serial number. I love the subject of statistics and because of this I know a lot of things that are repeated. And if something was not clear, then I looked for statistics assignment help, used https://ca.edubirdie.com/statistics-assignment-help for this. They told me it was boring and so on. But to each his own, some people don’t like chemistry or algebra. To each his own. According to statistics, the serial number on the HX Stomp should be located on the back of the device, or may also be on the box. Quote Link to comment Share on other sites More sharing options...
