Sending balanced monitor feed into unbalanced return inputs of HX STOMP
Smith_moh
Hello all, got a quick question.
I'm currently using the HX Stomp as an IEM rig. I think many might know the trick of feeding the monitor signal from FOH into the return inputs and using the HP out as an in-ear monitor amplifier. I have been using this system for a year now without any problems.
But recently I just realized that the return inputs of HX stomp are unbalanced. In my case, the monitor feed on the stage always comes as XLR so I use XLR - TRS cable into the returns. Would running a balanced signal into unbalanced input be prone to noises? Is it equivalent to running long unbalanced signal across the stage?
I don't really have a problem with my current setup and wouldn't change it. Just want to hear some inputs on the issue since I'm still not fully understand the balanced/unbalanced stuff well enough. Thanks in advance.
Balanced signal transmission has two benefits:
  • Noise suppression - this is more relevant with weak signals i.e. from microphones.
  • Possibility to lift ground. Ground loop hum can be annoying and lifting ground often is a fix.
Transformer balancing adapters like Neutrik NA2 F-J-TX or Palmer DI-REVERSE are good solutions to get those benefits in your situation.
IIRC, the Returns are unbalanced, so TRS is pointless. The devices referenced above are the way to go if you're concerned about noise.
