HX Edit Pilot's Guide 3.60 in German and Block names
naranja66
On 9/28/2023 at 9:08 AM, naranja66 said:
Are the instructions for the HX Edit Pilot's Guide 3.60 also available in German?
Can you also show the effect names or amp names at the top of the blocks instead of "Dyn, Dist, Delay, Amp. etc."? so that you can see right away what's behind it.
Thx :-)
It would appear that the HX Edit Pilot’s Guide is only available in English or Japanese at the moment.
Also, the blocks in the signal flow are shown with the generic term for that particular block, “Dyn, Dist, Delay, Amp. etc.”. Selecting any specific block (click on it), “Amp” for example, will reveal the actual “Amp” model used in the lower right section of the HX Edit GUI window, where you can the edit any, or all, parameters for that item. So by simply selecting a block “you can see right away what's behind it” and edit it.
Hope this helps/makes sense.
Thanks datacommando and Schmalle :-)
I've only had the HX Stomp for a short time and I'm actually really happy already.
When I experiment with it and like yesterday e.g. If I have 5 overdrives/distortions at the top of the blocks, it would be clearer if you didn't have to press on top to see what drive I've chosen. At least it should say what it is.
But I am also very satisfied.
thanks for all the help
On 10/4/2023 at 2:08 PM, naranja66 said:
Nice page, thx... :-) This is how it should be shown at the top of the chain... Great
Here is another great resource.
https://helixhelp.com
This is the most comprehensive list of models and blocks that you can find for every amp, cab, distortion, modulation, pitch, and other effects found on the Line 6 Helix, Helix Rack, Helix LT, HX Stomp, HX Stomp XL, HX Effects, and Helix Native.
