ColonelForbin Posted April 2, 2014 Share Posted April 2, 2014 I know it has to be class 10, and 32G or less - but is there a list somewhere (my apologies, I know I have seen it, just can't seem to track it down searching!) of the recommended, or approved SD cards that will work with the M20d? I am in the middle of trying to figure out if I have a defective unit, or what is going on, and in the service ticket L6 is asking me what type of SD card I use (it's a class 10, 32G, sandisk) Posted elsewhere, so won't go on about the details too much, but when I loaded the M20d up for the very first time, new out of the box, the touch screen did not respond; and it's happened almost every time since then. Calibrating fixed the problem, then it just did the same thing next time I went to reboot. I can't really blame the SD card since this problem occured on day one, with no card in it.. I bought it less than 30 days ago from Sweetwater, so in all likelihood will be sending it back for a replacement, rather than mess around with having Line6 attempt to diagnose it. L6 has been quite helpful, I have been messaging back and forth with them to get their take on what I should do. I will finally have time tonight to give it another test, but will probably just send it back to Sweetwater and get a replacement. It seems wrong that the touch screen would not work when the unit is new out of the box, but it's odd that I can eventually get the screen to calibrate, but not always - and that last gig where I had to reboot several times was quite disconcerting. I don't want to wait, then find myself with limited options. Anyone got any last minute advice or opinions or similar experience? Thanks Quote Link to comment Share on other sites More sharing options...
BucF16 Posted April 2, 2014 Share Posted April 2, 2014 Mine wouldn't record on first attempts. Then I re-formatted the SD card and it's worked OK since then. I have a 64gb card, which I only found out recently "isn't recommended" but I've used it several times and only had it quit on me once. Anyway, if you haven't tried it yet, re-format the SD card. And yes, they need to document their SD card limitations a little better. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 2, 2014 Share Posted April 2, 2014 I bought a 64G version of the card listed in the Line 6 Store on this website: https://www.globalfulfillment.net/gfsnet/line6/10Expand.aspx?ProductCode=97-000-0024 I had a bit of trouble formatting it in FAT32 but once formatted it has not given me any problem. The 64G vs 32G size hasn't given me any trouble (yet?). Quote Link to comment Share on other sites More sharing options...
pierrebriend Posted April 3, 2014 Share Posted April 3, 2014 ÃŽ have had, unfortunately, similar issues with my MD20 bought one year ago : freezing of screenplay : back to supplier, service and the problem fixed. Later, issues with the RECORDING using the right SD card class 10 : only tracks 1 to 8 were recorded...: once more back to supplier, service and the problem was fixed. By those days, I have another issue : loss of signal from LEFT analog output.... my m20d will for the third time go back to service...I hope for the last time...I like the overall concept of thr LINE6 soundsystem, when it is working well, but I would add that durieng my last public gig, I was not fully confident and a bit stressed... Quote Link to comment Share on other sites More sharing options...
